Finally figured it out. You need a T15 Torx, a 5/16 socket and a 8mm allen . Start by taking the license plat off under it is a small cover held on by one screw the T15. Then you will see the plugs for the light unhook it. Now the rear fender comes off four bolts holding the bracket to the frame the 8mm will do it. Then inside the fender are screws only remove the 7 with the 5/16 socket. Do not remove the 4 with the torx heads they hold fender to bracket. The outside molding will come off and thats where the wiring is. FRom then on smooth roads only. I be 88 and if I can do it anyone can. :yes::yes:
