Fjrwillie
I spent a lot of time with Garmin tech support and the tech said there are different ways to get the route to you device. He said the easiest and most dependable way is to "not use the send to device button". He said to simply drag the route from the bottom left directly to the root of the device at the top. Since it have started doing this - every-time I boot up the device I get "the you have new data - do you want to import it"
Works every time
You can also drag it the folder where Garmin would put it and use the Import Route Function as well, like Garmin said.
Willie
