How to quiet windscreen?
Thundercat
I have a 2012 RT when I hit bumps why windscreen sounds like it's going to fall off. I've checked all the bolts and there all tight. Any suggestions?
THIS WORKED
I made some plastic washers from the top of a KOOL-WHIP container, ( any of the thin plastic lids will work ) and put them on all the ARMS on both sides .......even when very tight they are very slippery, so they won't bind even without any lubrication........I have a set a various size hole cutters......I don't think you can drill them.......Mike :bbq:
Great Idea for the oil side cover. Those quarter turn fasteners seem to be loosing the plastic retainer washers to keep them from falling out. So far I have not lost one but need to figure out a way to make some replacements.
Question: Are your sure that the windshield is solidly attached to the bracketry? :dontknow:
(Sorry: I've got to ask...)
Make sure the windshield isn't all the way down. If you want it low go all the way down, then bump it up just a bit. If it's riding against the dash it could be making noise in a bump. It'll also risk breaking.
