Pennyrick
Thanks for the info. I just removed the shields below the mirrors and felt that helped with air flow but misses the target, me, so I'm a little perplexed at how being able to direct the air right to the driver with this vertika setup wouldn't help some? So, can you clarify that it doesn't direct the air to the rider? thanks again for the info.
john
To install the Vertica set up you have to remove the facgory shields under the mirrors. The air flows into the front of the Vertica device and turns down into the factory vent that is under the mirrors. It does not direct air toward the driver. The ram air effect is supposed to 'Flush out' hot air and it does it's job... it's just that we don't need more hot air flowing out of the vent on the right side or out from underneath.
