Hot tip - how I test the ACS air hose fittings!
Bensonoid
Next time you're in harbor freight pick up one of these blow guns. I didn't know this beforehand but the tube is 1/4 inch o.d. and slips right into the pushlock ftg's so you can easily test the ACS check valve before and after you clean it.
Not sure I understand. What is the ACS check valve? Does that apply to a 2021 RT.
If it's the base RT then you wouldn't have a check valve in the system, but if you have a model with Automatically Controlled Suspension then you do. The check valve gets dirty and can be removed and cleaned most times.
