Hose clamps
Bfromla
Well-known member
Fyi found out ,after a leak, :gaah:that the 998 has these crappy "crimp style" hose clams
attachment.php
attachment.php
Sorry i dont know propper name (&dont care)
:barf:Big chance for a headache. Hooe you dont get a leak like mine. ;)
If they are are installed and crimped properly, they will not leak. It does take a special tool to crimp them. My Thunder Mountain had them on the oil lines when I bought it. After 10 years they did not leak. I installed and re-routed new oil lines and after 5 more years I still didn't have any leaks. They are actually superior to the hardware tighten with a screwdriver clamps. Maybe someone in a hurry on the assembly line.
Thanks, Jerry! :thumbup:
Oddly enough; I was also going to volunteer "oetiker", to this conversation.
But your link clearly trumps me! :bowdown::bowdown:
Had the same type of clamp on a BMW S1000RR oil cooler that leaked. Ended up putting a regular clamp behind the factory clamp and problem solved.
Hi Bob,
Re: Thanks, Jerry!
No thanks necessary; we both want to help where we can.
Re: But your link clearly trumps me!
I know of them only because they are used in the parachute industry also.
More info is far better than too little info,
Jerry Baumchen
Thanks & agree with rushed assembly line guy. Fyi my repair was covered warranty thankfully didnt cause more problems. But held out for 25k miles. & ive never used that type before so know i might be a biased redneck. Thanks everyone for sharing
Contrary to Bfromla's experience and thoughts, Oeticker clamps are very good actually. If they leak it's because they were not installed correctly, or were not selected properly for the hose and barb size. That's all I used on all my PEX plumbing in my house. Almost all of the clamps are inside walls where leaks are very bad when they occur.
The standard pincer above is not exactly the best tool but no question it'll work. You just have to be careful to get the crimp done correctly. I used one of these. pretty hard to not get the crimp correct when using this one. It won't open until the clamp is completely crimped.
attachment.php
