..... Hope I'm answering everyone correctly.
Don't worry about it too much SpyderJerry, each
thread is effectively a 'conversation' made up of a collection of posts - so it's
meant to be read as a whole; and if you're still/really concerned, all you need to do most of the time is put the username from the specific post you're replying to into your response, just like I have in this sentence....
Or you can use the '
Reply with Quote' button to actually include a quote/copy of the post you are replying to in your reply.... just like I have above; only please bear in mind that everybody has very likely
just read the post you're quoting, so instead of parroting the entire thing back at them, it's only polite to edit out the unnecessary parts as I have done above! :thumbup: . Only if you do choose to do that, please try to leave the '
Quote' delimiters at each end,
AND the square brackets on either side of them completely intact - they NEED to appear before & after each 'quoted reply' as shown here:
[.QUOTE] ...the text you should edit to remove any unnecessary text/info from, leaving ONLY the bits critical for your reply to make sense... [/.QUOTE] (I've added the '.'s before each underlined
QUOTE just so the software doesn't read/take the command & apply it, hiding the important bits of what you need to ensure that you
DO NOT EDIT OUT!
As for making a mistake buying a Spyder - I doubt it will seem that way once you really get used to it, altho it might take some miles to get comfortable with the different ryding dynamics - only once you do, then the Miles of Smiles will really begin!
hyea: But like many others, you might find it easier/smarter to just ignore the BRP Connect balls-up completely alone as a poor attempt that failed miserably, and simply do your own thing instead of chasing your tail down the rabbit hole of trying to get it to work properly. If you really NEED bluetooth or a degree of integrated connectivity for some specific functionality that's not met by your helmet headset/alternative comms devices, then as mentioned by others, Motorcycle Dave will get you sorted! :clap:
