I purchased 2 Ram-HOL-UN7BU's via Amazon and BOXBAY LLC. About $25 a piece. I then trimmed off the 1 inch balls with a miter saw. Be careful to remove only the ball and just enough material to create a flat surface. You can then mate the two holders with glue/silicone (permanent) or peel n stick velcro. For the pic I temporarily used 2 sided white tape. I'll probably use silicone and remove entire mount when not in use. With the appropriate sized Ram Mount this method for center mounting would work for GPS, cell phone, etc. I like it because it's low profile. The Ipod is less than 2 inches above the handlebar bolts.
