HMT brake light
dbxray
how do you get the upper fender trim panel off? :dontknow: I remove the 8 screws as shown in the installation guide but cover will not move. is there a trick this is on a 2011 RT
You may have to rap it gently with the palm of your hand to pop it loose, then move it around or bend it slightly to get it off. If it is loose, it is just a matter of manipulating it. If it is not loose, you probably got the wrong screws somewhere...or missed some. It pretty much just tips back and out when properly loosened.
Did you remove the screws in the side compts. (saddle bags) The reason I ask this is because I had same problem and removed the screws from inside the rear trunk because I mis-understood the instructions. When it did not come off I looked at it again and realize my mistake. then removed the 2 screws inside ea. saddle bag.
Things stick together nice and tight up there... a little bit of "persuading" might be all that is needed for it to pop apart for you.
