HID Issue
lightman02
I bought an after market HID kit. It was plug and play so I didn't have to cut any wires. When I started the bike after putting them in the first time it was fine. Later I went to restart it and it would not start, the bike would almost start then stall. A couple of times I got warning codes on the dash but turning off the key and back on and all was normal. I know it's the draw of the HID's causing this as if I pull the headlight relay the bike starts fine. I put the bike on a charger for a few minutes and it started and I went for a 47 mile ride doing about 50. I got home and after and hour when to start the bike again and got the same issue. If I pull the headlamp relay and start the bike and rev it to about 6,000 rpm and have a friend put back in the relay while it reved the bike seems to hold started. So is it maybee i just need a full battery charge (I thought the 47 mile ride would have done it) or do I need something else?? My ballasts are NOT digital. Would digital ballasts solve this issue??? Thanks
The hid kit from Magic Man worked great! Thanks to Lamonster for the tip on taking off the dash my hands didn't fit either.
Lightman,
My Spyder has done the same thing after I was working on it for a while using power for testing, etc. It is just a low battery condition. You would think it would be recharged after an hour of riding, but apparently that is not enough. Charge the battery fully and see what happens. The spyders alternator is capable of 50 amps according to the shop manual. It also states the normal draw without power steering is 15-20 amps.
Matt
