Hey Finless....Radio/Entertainment plug/dongle/audio connections??
pitzerwm
I opened up the radio compartment and found this plug with a mating plug. See pix, what is it for?
attachment.php
Also where is the end of the entertainment wiring where I can tap into the audio line out wires. I see what looks like a 5-6 wire cable going under the seat towards the front.
attachment.php
Thanks for the help.
That is the entertainment harness. Do you have XM or CB? If you do not just unplug the harness at the radio (the plug on the radio to the outside of the bike).
Bob
I do have XM but not CB. Can I get audio line out on that cable? (the purple one) If so which pins? I remember you said that the "clip" on the plugs are on the bottom, do you push the clip up or down? If I have to take the audio out from the plug nearest the side of the bike, that is the plug that we talked about before?
