Here's my Battery cover access upgrade.
Uticat
So instead of having to get out the T30 torx wrench to remove the M6x12mm bolts, I just replaced them with star handled knobs in white from amazon. They are easy to see when you unzip the liner to access that area (black also available). Of course a wing bolt or any other type of finger tightening fastener will do as long as it's M6 x12.
Smart. Much harder to lose than the stock bolts. Now you've just got to figure out what to do with the other 8 that came in the package.
Probably donate them to fellow spyder riders at a meet-up, I sure don't have any use for 8 more.
You can probably go down to the local hardware store and find those knobs individualy that just fit over the heads of the torx screws. They should be pretty cheap. We used to use those on our Ventures to not have to get a wrench to take off the seat. Take a screw with you to see if it fits.
