porboy
Ok here's my problem. I keep blowing 10 amp fuses, been through about 8 so far. The fuse is for my tail light/brake light/mud flap lights. This is what I have added to my 2008 SM5 so far. Installed mudflap lights, they worked fine. Installed 12V outlet it also was working fine. Came home after about an 80 mile ride and noted the mud flap lights were out, changed the fuse, it blew, changed it again same result, did this several times. Disconnected the 12V outlet (put it back to original). Still blowing fuses. I'm the process of checking the connections on the mudflap lights to make sure nothing came loose. The only other thing I have added is the Bushtec trailer hitch only, (no wiring so far). When the fuses first started blowing it wasn't right away, I could at least start the bike and then it would blow. Now as soon as I put in a new fuses and turn the key on I can hear the fuses pop. Any suggestions?:dontknow:
