Help - want to change dash light color?
JJ38
Hi.
I´m JJ from Spain.
Someone change interior light bulb?
Sorry for my bad english.
Thank you so much.
If I'm not mistaken, those aren't bulbs, but LEDs, and should never need changing. If they are surface mount, not sure if you could change them if you wanted to!
Do we have any members in here who might be able to coax a bit more information out of him in a language that he's more comfortable with? :dontknow:
I'll try..!!
Qual es el problema con las luces. Al pareser estas indicndo que la luz del neutral esta fallando...poco mas informacion y seguro que,te podemos ayudar..:thumbup:
Hi.
I´m JJ from Spain.
Thank you so much.
The "N" is suppose to light up that way
:welcome: My 2010 Spyder RT-S Neutral light is the same as your Neutral light. The light is OK, it is supposed to be that way.
Gracias Chupaca.
Lo que yo quería decir es que sí alguien a cambiado las luces interiores para ponerlas de otro color.
Si puedes traducirles te lo agradecería,mi inglés es muy malo.
Gracias para todos.
Thank you for All.
JJ.
Chu,
I don't know what you did, or how you did it...But this is EXACTLY what this forum is all about!
:clap::firstplace:
What JJ38 is asking is if anyone has changed the dash light to a different color. This would be the panel lights, not the indicator lights... Alright guys, let him have it - I will translate... :thumbup:
Cuando responden te pasare la informacion. Yo no he cambiado las luces pero me imagino que seria question de tener bombitas de color. Veremos.. :thumbup:
Somebody did it here a while back, but I can't find the post. As I recall, it was not for the faint of heart. You could easily destroy a very expensive cluster with a mistake. You cannot merely "change bulbs", as there are no conventional bulbs.
Para JJ, lo que dice Scotty es que alguen ya lo hizo pero que no es facil Y una falla y se malogra el instrumental completo. Aparentemente no hay bombillas para el panel. No pudo encontrar la explicacion que publicaron aqui. Veremos que mas nos pueden decir..:thumbup:
This thread is awesome as we all speak the same language when it comes to our spyders and I think its great !:clap::thumbup:
Chu,
:clap::firstplace:
Yeah Bob, born and raised in Peru. If you saw me, you would not believe it, but Spanish comes in handy. My pleasure to help out whenever possible. That's what we are here for... :thumbup:
:thumbup:
I do recall a thread where the original poster changed the dash lights to purple... :shocked: It looked excellent; but it wasn't a job for the meek at heart...
JJ, lo que dice Bob es que tambien se aquerda de algen que camdio el color de las luces a morado y que se veia bien bonito pero que era bien deficil. Voy a ver si el manual de taller indica algo en referencia a esas luces.:dontknow:
Muchas gracias Chupaca por hacer de traductor,si alguien puede aportar algo más sobre como poder cambiar las bombillas o leds aportando fotos o lo que sea sería bueno.
Tambien me gustaría que dieses las gracias a todos los compañeros del foro de mi parte por intentar ayudar en sus respuestas....... Ahora me queda aprender algo más de mi mal inglés jejeje.
Quedo a vuestra disposición para lo que necesitéis.
Many Many thanks to All.
JJ.
JJ, Si te fijas en el post arriba del senor Bob..tiene un link (en rojo)donde hay fotos y una explicacion de como lo hizo. Las bombillas que vienen original so LED y no los convencionales. :thumbup:
