HELP: Rear running lights and tip lights no worky.
juscuz
Need help in figuring out why the rear running light and tip lights are not working on can am spyder rt (2018). Pulled all fuses, including the square ones in the fuse boxes, all good. Even replaced with new fuses in case problem with fuse not visible. Now I'm thinking it may be a relay. Which one and it's location in the box if anyone knows or have had this problem before. Stop, turn and backup lights are ok.
Rear Running Lights
:hun: Not real sure what you are talking about. Are these 'Running Lights' an add-on or Factory? Let everyone know and maybe someone can help you better. ......:thumbup:
Rear lights
referred to in the original post is the factory center section which is normally always on when riding. The operations of the stop/turn signal and reverse lights all work properly but the sealed center portion with the two small screws that looks like a bunch of eyes encased seperately from the two outer bulbs don't work. You would have to see the rear of the light to probably understand what I'm referring to, that's the reason I was asking if anyone had this problem and what was the fix.
