..... but I just want to be sure I do it right.
When talking about wire isolation, What would you suggest?....
Nothing 'extra' Bernard.
The only 'issue' here is that we've discovered a few (VERY few) gauges have started showing high readings when the coolant temp really wasn't high at all!! So if you ride your Spyder beforehand, have a look at where the gauge is showing the temp; then do the Magics Install; once done, go for a ride - if the gauge climbs fairly quickly right up into the red & stays there, then since you just rode earlier & your Spyder wasn't over-heating, chances are it still isn't overheating & your gauge is reading incorrectly.
If anyone tests the gauge off the Spyder, it will work fine; if you remove the Magics, it will once again work fine & won't show any fault - not unless something else is wrong with it anyway! And so far, every confirmed instance of this (5 out of about 1000 installations) has either been clearly due to moved wiring, usually with poor quality joins or insulation too, bringing the wiring from where it should be, behind the gauge & towards the middle of the 'behind the dash cavity' over to hard up against the inside of the RH mirror mount where the wiring with poor quality joins or dodgy insulation has been able to move & rub & fray & do all sorts of stuff wiring should NEVER do, including picking up the tiny (& I do mean tiny!) amount of magnetic field that can be detected thru the frame there, or it's somehow been due to the polarity of the mounted magnets & is readily remedied by flipping one or more until the false 'high reading' goes away!
How to avoid this false reading? In the first instance, do nothing but check the gauge before & after installation as mentioned above - the odds of there being a problem are pretty small (so far, 5:1000+, possibly marginally higher; but still very likely less than 0.1%!!) So if you DO have a problem appear with your temp gauge reading & you don't think your dash has ever been opened, try flipping the RHS magnets one by one & watching what your temp gauge does; if that resolves the problem (as I suspect it will) I'd still suggest dropping the dash to check the wiring inside for any potential or pending problems with the wiring & make them good, ie, proper plugs or spliced joins with insulation/heat shrink tape over them! And if you already know your dash has been opened, do all the above but CERTAINLY check behind the dash & make sure any extra wiring is at least about 50mm away from the inside of the mirror mounts &/or has proper joins & patent insulation with any exposed wires covered & everything secured so it can't move around &/or fray/wear!!
And if you still have concerns, talk to Russ/Merlot, I'm sure he won't have any issues with you returning the kit for a refund!
It really isn't anything extra hard or even unwarranted, just make sure any wiring additions are done properly & maybe flip the magnets to avoid any polarity concerns, but unless there is already something 'improper' with any extra wiring in there, the chances of this 'polarity' thing being a concern are quite small! :dontknow:
