wmh9680
Good Evening Everyone, Hope everyone is still out riding. It's chilly here in Chicagoland.
Well I did my 19.000 oil change and replaced the air filter okay. Now I just replaced the fuel filter and before I put her all back together I thought I would try to start her up to check for leaks. When I turned the key on it seemed normal but nothing happened when I hit the starter button. The lights were dim and flickering like a weak battery or bad ground or something else electrical. Nothing turns over or tries to at all. Could I have loosened a connection somewhere on the air filter side or the around the fuel Filter.
Thanks, Mike
Thanks, Mike
