Heated Grips
ataDude,
I checked out your picture and have a question. The control assy. on the right side handle bar, is there a locater pin (or something) that prevents movement to far right or left. Or, can you place it where you want and just lock it in with the torx screws?
After I mistakenly ground the locator pins off of the plastic housing, I placed a stainless, self-tapping screw into the handlebars (hidden "inside" the assembly) to prevent movement. You definitely want a positive stop or the entire assembly could slide off during aggressive left cornering. Don't depend on the Torx mounting screws to prevent that movement!
See:
http://www.spyderlovers.com/forums/showpost.php?p=42913&postcount=35
