Heat sink paste
But can I use the 99.9% pure sliver paste?
It is hard to say for certain, but if damage occurs using a material that is not the equivalent of what BRP specifies, there could be warranty problems. I would not use something containing a dissimilar metal. It could cause electrolysis and/or corrosion, between the alloy head and the steel spark plug. This type of corrosion is why you should never use anti-seize compounds for aluminum parts. JMHO
:agree:I used anti seize on my Dodge truck lug nuts [aluminum wheels]
With in two months the clear coat started to peal and the aluminum is corroding.:yikes:
I went to radio shack to get a tube of the heat sink paste and right beside it was a much smaller thermal compound (the expensive one $10) so I went with this one, they told me it's better than the $4 paste. After I got home I looked at the back it says 99.9% pure silver, can I use this one or I need the other $4 silicone tube one
They told you it is much better than the silicon paste, and it is when using it for computer processors as it was designed for. I am not so sure it is going to be better in this application though. They should be willing to give you your money back though. I just bought some last Friday for $3.20 out the door, the part number is 276-1372[A].
Hope that helps.
Only 3K miles on plugs??
I hadn't thought about plugs yet as I approach 3K. My Goldwing had 66K on the OEM's and still ran beautifully. Is this a modern engine or not? :dontknow:
It is a modern engine, but it seem to have it's quirks.:dontknow:
I pulled my plugs at 11 thousand miles, They were perfect.
But since i had them out, and allot of posts were saying go to iridium
plugs they are better and will last longer, I tried them. Didn't like them from the moment i put them in,
12 hundred miles later pull them out they looked like they had 20 thousand miles on them. I said this many times what works for one Spyder doesn't always for another. You'll see on quite a few posts someone will add something that didn't work, and it did work for some others.:dontknow:
P/S Only once i had to change plugs in a bike with under 15/20 thousand miles.[not counting 2 cycle]
Any difference between 276-1372[A] and 276-1372? I just noticed the tube I purchased is 276-1372.
Just changed my plugs today, one had heat sink paste, one didn't, and this is right from the factory. It goes without saying, both now do. :lecturef_smilie:
Don't do this! The heat transfer properties are not nearly as good, and anti-sieze compounds are notorious for causing corrosion between dissimilar metals.
Good thing I read Spyderlovers.com. I just went to Advance Auto Parts and they told me they always use anti-sieze. I turned them down and will try Radio Shack.
