I have a 2012 RTL and get a lot of heat on my right foot. I thought the heat was coming from the radiator so I cut out the plastic piece
under the radiator outlets and blocked off the upper and lower outlets. This didn't solve the problem. To find out what is causing heat problem I purchased a digital laser thermometer form harbor freight that you can aim at area to measure temp. After going for a ride and the temp gauge not showing that engine was running any hotter than normal I measured the temp of the block off plated area and it showed about 90 F so then I measured temp on the silver metal piece at bottom of body panels just inside the floorboard, this showed 150 F. So looks like this is where heat is coming from. Question is.... has anyone else had this problem and anyone know of a way to reduce this heat?
