Headlights override button?
PLZDVM
I am a bit confused, the manual describes this headlight override button being used when riding.
Mine will only flash when the engine is turned off.
Questioned the dealer and was told this is the way it works.
Is there a fix for this, or is this the way it is supposed to operate?
I know my hi-beam switch works on my RT LTD but I'm not sure if I had the fog lights on. If it works like automotive lighting the hi-beam lights will not come on if the fog lights are on.
on my RS-S the fog lights have no barring on the high beams.
On the right handle where the Mode button is on the left is a switch but it only turns the lights on when the motor is off. it does nothing if the motor is running.
The button on the left side of the handlebar is for flashing the Hi Beams' The button on the right side in the back of the bar is for turning on the lights with the engine off [as long as you keep the button pressed]
Also on the GS with the trunk open it will reflect light into the trunk'.
LOL, read the manual cover to cover but missed the "flash high beams" on the head light switch.
Thank you
