Headlights: Other than HID lamps, is there another 'bright' bulb option?
High and low beam
Don't waste your money. They are NO brighter at all --- actually give out less useable light as they are tinted bulbs--- people just think they give out more light because of the purplish/bluish appearance of the light.....Been plenty of tests on these-- and they simply cannot put out 'more' light... it's physically impossible...
Buy the VOLT version from Xenondepot--- they work just fine.
Does that hid kit have high and low beam ? I have a 13 RSS I haven't checked to see what bulbs I have yet I was just curious . Thanks to you all for discussing on here.
No separate high and low beam on North American Spyders (except ST?). They use a shutter to cover the top of the lens on low beams.
I have the HID kits from Xenon Depot. Really makes a difference. They come with everything you need. I will caution that if you are going to install them on an SE, use the extra harness that goes to the battery. It might save you from some spurious code issues. I also tried H11 bulbs for the fogs. They will not fit in the housing even though they are a replacement for H8 bulbs.
Thank you bruiser I have a 13 RSS sm5 . Are the headlights H8 bulbs ? It seems everywhere I read they are talking about different bulbs some say H7 some say H8 :} I need to pull one out I guess to make sure
First off IMHO there is NO substitute for HIDS and that BRP kit is great and would not trade mine for any other kit out there.
You can find high wattage H7 bulbs being higher then the standard wattage H7 bulb but higher wattage means higher power draw and higher heat. Which you can run the risk of melting wiring that was not designed to run those.
They do have high powered LED bulbs out there now running CREE and even have built in fans for heat. They may do the truck for ya
bruiser: Thank you so much for taking the time to post up some feedback. I'm glad to hear that you are happy with the low beam upgrade.
xllxmrjohnxllx - According to my info, you would need to order an H7 HID kit to upgrade the low/high beam on your Spyder. I believe that your stock headlight bulb uses an adaptor to hold the stock H7 bulb into place which means that you would need to order this H7 adaptor in addition to the kit.
Steve
H7 headlights, H8 foglights on the RS.
Some Guy: You would need to order a 9005 HID kit to upgrade the low/high beam on the RT
xllxmrjohnxllx: Im 99% sure you're going to need that adaptor. You can check by pulling out your stock H7 bulbs, and checking to see if they plug into an adaptor or if they are simply held in place by the standard retaining clip.
Steve
I ran ZXE light on my VTX, and I currently run them in my Silverado as well. The difference is above and beyond. Advance sells them and normally has a pretty large selection of them. I am going to be working tomorrow on getting a set on my F3-S to see how they do.
