Headlight replacement bulb for 11 RT?
AeroPilot
Have the first bulb burnout for the 11 RT after almost 4 years. I will replace both bulbs with similar 55W halogens when I tear down the tupperware to get to both headlights, and hopefully be good for another 4 years. I do not want to go with anything fancy like LED's but would like to know what others use for a replacement bulb,,, the Osram 64193, H4, H7? or I guess, I'll tear it apart and then carry the bulb until I find a replacement. I imagine my dealer would have to order the BRP 55W halogen.
ONEEYE
Let's see..!!
most of the older ones used the H7 single filament bulb type. At the autoparts stores you can find many brands with whiter/brighter or blueish beams and the ones I have tried work well. The parts list says yours is an HB3 65w bulb and sells for $17.95. check your manual and take a bulb with you to make sure. :thumbup:
Be sure and get a HB3, some others look the same but the mounting part is slightly different and don't fit.
