Headlight problem
I have an F3-S with LED's also. The only thing I can think of is that you might have a bad headlight switch on your handlebar cluster.
Replaced headlights and foglamps with led bulbs on 2014. Rt installed tricled 360 headlight bulb's and right bulb would not illuminate, when plugged left headlight assembly in right harness bulb would work , plugged hid bulb in would work. Started inspecting harness and polarity found connector inside cover at bulb wires in rong position in two pin connector from factory. Connector is marked positive and negative and the black wire(negative)was in the positive postion,reversed wires in connector and led bulb works like it should, on the left side connector the wires were in the correct postion. (Tricled 360 led headlight bulbs will fit inside cover with no cutting or mounting outside of cover)
