Head Lights
Actually, KuryAkn makes a meter that you can stick on using 2 sided tape (supplied) most anywhere is and is pretty small. It has two wires; one you run to the battery and the other to a ground; that is, any bolt on the frame. You would have seen the meter peak and show LEDS OVER the green which is the good zone. You should have quit riding at that point and parked the bike and perhaps even had the regulator/rectifier checked. Not sure where your battery is located but if you put a multimeter, set to a low value VDC scale connected to the positive and negative battery terminals and started the bike you would have seen voltage way over the 14 VDC or less than is expected and KNOWN FOR SURE your regulator rectifier was not working properly. In fact, just observing too-high voltages on the KuryAkn meter should have parked the bike and gotten it to service.
http://www.revzilla.com/motorcycle/...&kpid=952756&gclid=CKyK1LyEzsYCFQiEaQodMzcIqw
;) Very cool I can even do that I will get me one if I get my Spyder back thanks... jtpollock
Since you've had all that trouble, I've got a kuryakyn meter that I don't use anymore, and you can have it (no charge). It is set up with a powerlet plug at the end, and it's also set up with a ram ball mount.
:bowdown: sent PM... jtpollock
Things are looking UP
To all that have replied thanks for your input... :thumbup: Got my Spyder back late Saturday and did a test ride on Sunday all looks good except my Spyder savings account it's empty now:(... Rode into work nice 40 mile this morning :yes: no worries it's nice to be back on the road it will take a few more days to get my confidence back
but we leave for Deadwood on Thursday morning I'm so ready for a road trip...
Once again THANKS to all ride safe enjoy the Summer :). jtpollock
