IdahoMtnSpyder
Yes, I know that. I guess I should have made it more clear I was responding specifically to this part of RICZ's post:Headlight modulators are DOT legal in all 50 states.
The regulation, as you quote above, states:but I snip off the photocell and install a switch and place it on the left handle bar...... at night. When confronted with a left lane bandit at night, I flick it on and they move over pronto.
As soon as you cut the photocell off of the modulator it no longer conforms to the rules regulating modulators. That means the modulator is no longer legal. Note that the regulation uses the word "shall". That means it is mandatory, not optional. Why? The sensor is required so that the modulator WILL NOT operate at night. By making the on/off operation dependent solely on a switch you have defeated that restriction. So, again, as soon as you turn your modulator on at night to get a crowding driver to move over, you have violated the regulation.(f) The system shall include a sensor mounted with the axis of its
sensing element perpendicular to a horizontal plane. Headlamp modulation
shall cease whenever the level of light....
It's because of these violations of the regulations controlling the operation and configuration of the modulator that I said RICZ had better hope the oncoming driver isn't an LEO. Use it ONLY during daylight and you'll be OK.
BTW, you can add a switch into the photocell wire to turn the modulator off during the daytime. Just leave the photocell in the circuit so it'll turn the modulator off at night and you'll be OK.
