UPDATE: Having to reset saved audio/radio settings over & over
Heard back from RadioSound with their conclusion after analyzing the problem. Looks like it will be up to BRP to address according to the correspondence I received (see below):
Hello Tony,
Yes sir. That is what the engineers are saying. The radio doesn’t save the display settings/options. The radio stores the radio settings in static memory which will not disappear over time. The gauge is what sends the display settings to the radio. If the gauge has changed the settings, those are the settings the radio receives.
When you have to reset the radio is there a specific time frame that has passed or is it intermittent? You’ve said a couple days, is that when it is setting without being ridden or are you riding during this time?
Thank you,
Arlene
Phone (800) 367-4506
Fax (502) 267-6794
E-mail
[email protected]
mailto:[email protected]]
Sent: Wednesday, August 28, 2013 2:12 PM
To: Arlene Henry
Subject: RE: 2013 Can Am Spyder ST-Limited
Thank you Arlene. Are you saying that my problem is, in fact, related to the gauge (or instrument cluster) on my Spyder? If I am understanding you correctly, the instrument cluster (or a memory chip inside the cluster) is in need of some sort of repair…and this would be a Can Am (BRP) type of repair rather than a RadioSound repair?
Sent: Wednesday, August 28, 2013 10:52 AM
To: Younger, Tony
Cc: Customer Service
Hello Tony,
Our engineers believe the problem may be with the gauge. When the radio settings are changed, the gauge sends the new settings to the radio, and the radio will save the settings on the next ignition cycle. The radio stores the settings in static memory which will not disappear over time. Also the radio doesn’t save the display settings/options. If the gauge inadvertently changes a setting, the gauge sends the new setting to the radio which will update the stored settings.
If the settings are disappearing over time, it may be the way the gauge stores the settings. It could be in a memory chip which requires constant power, and that circuit is defective, so the gauge settings are lost after a period of time.
Also one of the entries on the forum from 7-29-2013 stated that they updated the computer and had to reset the audio settings. Replacing the computer should not affect the audio settings saved in the radio, unless the computer told the radio to use new settings.
Thank you,
Arlene
Fax (502) 267-6794
E-mail
[email protected]
I sent the e-mail this morning and, although I didn't get a cause for the problem, I did get a response indicating a rep is checking with the engineers regarding the problem. Stay tuned...
Sent: Tuesday, August 27, 2013 1:49 PM
To: Younger, Tony
Hello tony,
I am checking with some of our engineers about this. As soon as I have some information I’ll get back to you.
I’m sorry for the delay.
Thank you,
Arlene
Fax (502) 267-6794
E-mail
[email protected]
