garyleblanc1
Hello, has anyone had success finding a hauling trailer for the RT? I checked out the Ultimate Trailer and it is awesome as well as it's price.
Any suggestions?
Any suggestions?
Any suggestions?
Check out thread I started a week or so ago.
http://www.spyderlovers.com/forums/...Flat-Bed-AluminumTrailer-for-Hauling-a-Spyder
Just go to a place that sell trailers, and tell them you need a 10ft long tail and 6 ft inside width with a loading gate ! You have to put some boards on the outer edge on the ground where your front wheels drive up on the rear gate to keep your nose of the spyder from hitting the gate before your front wheels get to it. Cost of trailer $1250 or less! Cut you 4 pieces of 2x6 boards about 12 inches long! No cost on boards use scraps boards! Get one with a hinged rear gate, and it will save you on cost of gas pulling it! Tie front wheels down both forward and backward using tie downs and you are in business!:bowdown:
thanks
Enclosed trailer for us. All aluminum, 7x12, with brakes. Barely weighs more than the Spyder. Once you get to where you want. You have the added security of the trailer to park the Spyder. Another added benefit. The Spyder is out of the elements. Both when towing it, parking it. :thumbup: Tom :spyder:
What Brand, Make, Model is it, Always helps to have someone else's specific suggestion, I'm hoping this cost less than the Ultimate Trailer the OP was referring to.
These are a couple of photos of the 6' by 12' trailer with a dove tail and folding ramp I purchased for under $2,000.00. Still have to use 2 short boards so the front end will not hit the ramp when loading. The 6' wide trailer tucks in good behind the pick-up and does not catch much wind. I had to order the 6' wide trailer.
View attachment 149985View attachment 149986[/
What ever works for u is ok. I would not want a trailer with ramps that are useless. I dont want to pack boards around to load Spyder
Any suggestions?
