Harvey's air mgmt. system question
wyliec
Harvey or others that have installed it,
I know the bottom plate needs to be removed to cut it. I got under the bike and checked it out and it looks like that bottom plate is connected to the plate in front of it. This is my question: does the plate/shroud above the bottom plate need to be moved to get to the screw that attaches the bottom plate to the plate in front? I just want to be sure before I dig into this project.
Thanks
There are 2 bolts mounting it to the center frame you can see from the underside and one hex screw on the front, just under the side fairing. Nothing else to undo to pull it out.
Thanks Sam,
I'll give it another look. I just thought I saw where the panel in front was connected to the bottom panel. I'll have to wait until the morning.
