Hard knock when placed in Reverse
Blade
Hi all, every time I put my spyder in reverse I get a hardknock. Is this normal. It seems to happen the first time I go to back out of my garage but after riding it doesn't knock as hard.
Blade
Blade
Pretty normal, after the bike warms up and gets the oil flowing good it lessens the shift, but be sure that your oil level is full.
Cruzr Joe
This is the one place where the saying "they all do that" is right on the money.
If your mechanic tells you that...watch out. :yikes:
The first shift of the morning always goes KLUNK...big time. This has been the same across all five :spyder2:'s I have owned.
If you go from First to reverse by holding the button and shift paddle down when shifting most of the time it is quieter. In other words push the "R" and hold the downshift paddle until it is in reverse. Of course this only applies to Auto shifts trannies. Essies. :thumbup:
You are absolutely right, Dave. And it works both ways - first to reverse, and reverse to first. Holding that paddle down is both quicker and less clunky. :thumbup:
Blade
Cruzr Joe
Agree with everybody's comments. Motorcycle clutches like these are multi-plate clutches with very tight clearances in between the plates when the clutch is disengaged. They are wet clutches which means the entire assembly is bathed in engine oil. The viscous drag of the oil between the plates is enough to keep them slightly turning even though the clutch is disengaged. Thus when you put it into first or reverse, it clunks as now you are engaging the gears and stopping all rotation. As the oil heats up and gets thinner, there is less viscous drag and less clunk.
Blade
After starting you will notice about 1200 RPM. Let it idle a few seconds until RPM drops to around 900. This gets the oil circulating in the transmission and it will shift with a lot less hard knock. (an old Indian trick I learned from my Grandpappy)
Jack
Jack
I didn't know the ponies the Indians rode had wet clutches :roflblack:
Isn't that how you normally shift. When I start up its always in neutral. Going from neutral to 1st or neutral to reverse clucks. Maybe I'm missing something, please walk me thru your shifting to lessen clucks. Thanks. Jack
You are not going to avoid that. What Rob and I were talking about is going from 1st to Rev or vice versa you can lessen the clunk by holding paddle down between those. :thumbup:
attachment.php
  • lakota-artist-jim-yellowhawk-indian-motorcycle-native-american-indian-BNNKJ6.jpg
"Clunk"
Mine does it, I've read somewhere that maybe full synthetic oil helps and will consider that at next service. Guess the clunk is normal but if I could change one thing about my Spyder it would be that, it makes me cringe every time!
Reverse to first works that way also, really? I've never been able to get it to do that. Must not be holding the buttons down long enough although I thought I did. I wondered why that feature didn't exist. Another case of operator error???? :duh:
Jack
That's for the 1330, right? Idle for the 998 is 1400 and I see it drop to that pretty quickly after starting. Still get pretty good clunk!
Ahh, you'll get used to it after awhile! :thumbup:
