Lamonster
SpyderLovers Founder
The chances of that are about as good as you showing up on time somewhere. :roflblack:What happens in the case of a tie or multiple contestants with identical scores?
You are deducted 1 point for every minute you are off the "Ideal" time.
Necessary Spyder RS/RT parts (to follow 4-6 Spyders in the pit truck):
1. Front wheel with tire mounted: 2RS + 2RT
2. Rear wheel with tire and bearings mounted: 2RS + 2RT
3. Driving belt: 2
4. Clutch complete with plates, springs and basket: 1RS SE5/SM5 + 1RT SE5/SM5
5. Front sprocket with compression screw: RS
6. Spark plugs
7. Fuses and relays
8. Oil, filters and seals
9. Bulbs: OEM, LED and HID
10. Front/Rear brake plates gen.3
11. Tools
:chat:
I wonder if you can pull a trailer or MC camper like the one Scotty has???
50 point bonus for sleeping outside near bike------:thumbup:
Me too...and that worries me.............a lot! nojokeYa know, I kind of like it.
Rules say "No support vehicles of any kind shall be permitted during the Rally."
Did anyone notice the part about lodging? I've read that if you take a room (with a bed and shower) it doesn't cost you any points. But if you sleep next to your bike you get 50 points added to your score!
If you lose a point for every minute you are early or late, 50 points means you could be almost an hour off and still end up breaking even our gaining points.
I guess the hard core, I came to win guys will be sleeping next to their bikes all night.
Yes, that has been mentioned a few times in the thread. It is apparently considered part of the Guts portion of the Guts and Glory name. Good pickup on the fact it would help you out with getting closer to the appropriate time for each leg, and the fact if you slept out every night it could help you end with more points than you started with as well. :thumbup:
Hooligan tent:But with 11 check points (assuming the 11th won't have a sleep for points component) that is still 500 points you can earn from sleeping with your bike.
I must admit, I didn't take the time to read through all of the posts for this particular point.
But with 11 check points (assuming the 11th won't have a sleep for points component) that is still 500 points you can earn from sleeping with your bike. And it will save the promoters quite a bit of money in lodging fees too.
For the ones who go to win first and everything else 2nd, I suppose it will be a no brainer. For the rest of us it's something to consider.
Looks like you can now.I did try to registered into The Hoka Hey Challenge: no three wheeler allowed! nojoke
Motorcycles:
This year's event will be run in two divisions. Division 1 is open to aircooled American-made V-Twin motorcycles, and Division 2 will consist of all other makes and models. The different divisions will be departing separately and the motorcycles will be running against motorcycles within their division only.
http://hokaheychallenge.com/about.html
