SteveandBelinda
I am installing a trailer
harness on a 2014 RTL. I ran the hot to alternator terminal, and trying to find a do-able place to ground in the mid part of the bike. Most stuff is plastic or brass threads in plastic. Not sure this is kosher or not, but the most convenient and nearest place to the end of the ground wire is either on a bolt that bolts the gas tank to the frame , or there is a stud at the top rear left side on gas tank, that I could put connector on, and a nut.
Trying to get this all buttoned up and need some opinions.
Check the attached picture of where I am talking about.
