BilltheDiver
Do you guys use any type of lubricant or preservative on the body panel grommets to keep them from drying out or getting brittle?
I use a lubricant that is designed for swimming pool fittings. It is not as slippery, but stays on the grommets from season to season, and is designed for rubber/plastics so it does not dry out the grommets like the alcohol content in Windex might.
Available at any swimming pool supplier and/or online.
The green stuff I use is just like that.I use spray White grease very little just to get the panels on..And the lube goes away and doesn't cause the panels to panels to blow off because I lubed the knubs a bit . [emoji106]:shocked:
Spit happens
