grips
I also went with the Kuryakyn ISO grips and love them. They are a bit larger and longer but quite comfortable. I also had them on my Harley for years, never had any chrome peeling issues. Lamonts video install makes it quite easy instalation.
What about Heated Grips?
Does replacing the grips with any of the suggested types above disable the "Heated" functionality? I've got an RTL w/heated grips and had been told that they could be replaced with anything else without losing their ability to heat up.
Is that incorrect?
Is that incorrect?
The Grip Puppies and/or clones work well with the heated grips.
[QUOit didE=NorCalBud;844941]Does replacing the grips with any of the suggested types above disable the "Heated" functionality? I've got an RTL w/heated grips and had been told that they could be replaced with anything else without losing their ability to heat up.
Is that incorrect?[/QUOTE]
Yes I did it works fine
Grips
I used a black foam they use for hot copper pipe if you get the right size that fits straight over your original grips does not need soap fits strait on and does not effect heaters and is like memory foam ,the only thing is its a bit bigger than the original grips.they last for about 2 years are very comfortable and only cost about $3.00 for a mtre that gives you about 5 sets.so for that they would have to be the cheapest grips around. Not for everyone because they do feel big.
hand grips
Anyone have any good recommendations for hand grips? I am getting tired of getting "grooves" on my hands from the stock grips. also, anyone know who does laser alignment near Knoxville, TN?
Thanks,
Seth
I put self adhesive tennis racket hand grips on mine. Works pretty good and you have colors to choose from
