Grips to small
Ctider07
I have the 2016 rts with heated handles and my hands get cramped with longer rides and old age. Are there bigger grips that can be slipped on with not to much DIY $
Sent from my SAMSUNG-SM-T337A using Tapatalk
Get some grip puppies. They are reasonably priced and easy to slip on over your stock grips. Spyder pops has them.
Sent from my VS990 using Tapatalk
I got a set of leather grip wraps off of ebay for about $20.00. work well and no sticky either.
If you want some really pretty ones, Kuryakin(sp) has some nice clamp ons that go over the Goldwing heated grips. If you have an SE5 there is some modification for clearance but not bad. Do a search for the threads on this. I did it and the heated grips still shine thru,tho it takes a little longer.
check this out http://www.kuryakyn.com/products/275/iso174-grips
see post #12
Ya trying to tell us ya got big hands and uhh---
:D
Loosen up your grip will do wonders for your problem. Your handle bars are not the same as bull dogging a
steer with horns. You do not need to have a white knuckle grip. It will stop the cramps and smooth out
your steering. Try it--you'll liked it.
Jack
$6
$6 @ LOWE's.....
para-cord....
i wrapped it from inside to the far end of the grips...
added just enough in diameter to make things a lot more comfortable...
Dan P
SPYD3R
Tricled foam grips
Go to Tricled, a site sponsor, they have an outstanding foam grip. I think they are $12 or two sets for $20. They work well for what u wanted, does not affect heat, cooler in summer, and easy on and off. They seem to last long and work perfectly.
Joe
I second Tricleds. 5 minutes in the parking lot with hand sanitizer for lubricant and they're done. Hands don't sweat in summer but warmers still work great in the winter. Dense, open cell foam works great ...
thehawk.
:D
Jack
Yes for sure but old Arthritis kicks in about 50 miles out from go. #rideforfunnotpain.😆
Sent from my SAMSUNG-SM-G920A using Tapatalk
The answer depends on how much work you want to do and how much you want to spend.
The cheapest and easiest way to go is Grab On Grips Grip Covers (pr) $12.50. We can not bring enough of them when we go to Spyder Events. I actually use a set on our HD Ultra Classic.
On our own Spyder RT I installed the
Kuryakyn ISO Grips for use with OEM Heated Grips. GL1800 06+ & F6B Models.
Will work on Can-Am Rt Heated Grips with modifications.
This will require some modifications but for the money a must have for anyone wanting comfort.
Grip puppies. They're available from several SL sponsors. If you come to Spyderfest, you may get some as a prize at one of the host hotel parties.
