bertmc
My RT belt started squeaking a little on acceleration in lower gears at a couple thousand miles & the tech a Cowtown told me he put a little grease on it. Worked pretty good, but now about 5 or 6 thousand later it is squealing like a stuck pig. The service bulletin posted at http://www.spyderlovers.com/forums/showthread.php?47037-squeal-noise
says to dab on some XPS Synthetic Grease (little bitty dabs, less than that Brylcreem dab, Bob. Of course, Bob probably doesn't have as much hair as he had in the '50s, so he doesn't need as big a dab of Brylcreem either! Just enough to make his scalp shine!).
I found a MSDS for it which says it is a "semi-synthetic lithium complex grease."
I don't have any and don't want to drive 140 miles to pay probably $20 for a tube to use a few dabs from. Would it be OK to use my Mystic JT-6 Hi-Temp No 2 EP Lithium Complex grease? I see that Mystic also makes a semi-synthetic, so maybe I should try to find that one locally?
Or would Brylcreem work? I heard Bob uses it to polish his Spyder.
