scottnkansas
I pick up my new RT on Tuesday. The one I had before was a limited and this is an RT-S. So it does not come with GPS. Any suggestions on mounts and a good GPS for motorcycles? Thank for any help.
Scott
Scott
Hi, I use my iPad Mini mounted on my dashboard on a Ram Mount, works great. Large screen and uses the Map App for destination and turn by turn directions. Use my Sena headset to sync the system. Make a great day. PacoI pick up my new RT on Tuesday. The one I had before was a limited and this is an RT-S. So it does not come with GPS. Any suggestions on mounts and a good GPS for motorcycles? Thank for any help.
Scott
My last bike came with a Garmin Zumo 550. It included City Maps software and something I could plan routes, way points, etc. on my PC, then load it into the Zumo. My new Spyder RT came with a Zumo, but there was no software and no instruction manual - only mounting instructions and some extra mounting hardware. Did my dealer give me everything, or is something different now?
Yep. It's the 660. I apparently got the same as you, but without an explanation. Thank you very much!Assuming you're talking about the Zumo 660...the map is preloaded and can be updated as necesary via Garmin Express (free download from the Garmin site). The computer interface for interacting with your map and then transferring data to your GPS is Garmin BaseCamp (also a free Garmin download). You can also download a free users manual from the Garmin site. It sounds like what you received is the same stuff that I received.
If you liked that setup; why not re-create it on your new RT-S?I pick up my new RT on Tuesday. The one I had before was a limited and this is an RT-S. So it does not come with GPS. Any suggestions on mounts and a good GPS for motorcycles? Thank for any help.
Scott
I mounted my garmin 660 up on the dash using Thorton mount. Love it!View attachment 100401View attachment 100402
I have the same mount and GPS and was wondering how you ran the power cable. How did you handle the mic and headset plug-ins on the Garmin cable? I wanted to run the cable where the "dash" top and bottom join but haven't found a way to split them. Thanks for any info.
Gary C
First of all, I use bluetooth so no cables go to helmet. I left all the original cradle, cabling and mount installed on bike. I bought a new garmin 660 cradle & Cables as well as the Ram mount and Thornton mount. It was very simple to trace the OEM gps wiring. I was able to spilt the dash and drill a hole for the wiring on the rear dash lip. Passed all the cabling down and along side of the OEM stuff, zip tied wiring, unplugged Garmin wiring from OEM harness and plugged into new harness. Splice in the red and black wire and you are done.
GPS cradle and wiring
