Which model & year is your Spyder, Classy?
My 2013 RT Ltd came with a Garmin Zumo 660 & mount (same GPS & mount as the retail Zumo's except with BRP proprietry wiring set-up & map set, so you can't just swap in the std retail versions! :sour: ) but I'm pretty sure that within a couple of years of mind the GPS Model had changed, then changed again just over a year after the first change, and then BRP stopped including any separate GPS & mount on the 2018's & up......
