shrubs
On your spyder:
go to settings -> audio -> make sure your speakers are on. They should be as your hearing FM radio but double check.
Then go to headset and check you have it on mix, if you have it on mute or off and your testing the GPS voice with out the head set on you will not get the right results.
On the GPS:
From the main screen choose audio, make sure mute is off and volume is 100%, then go into mixer and set both master and navigation to 100%
Then back the main screen go into tool -> settings -> system
make sure the usage mode is motorcycle (audio is handled differently between car and motorcycle mount)
This worked for me. I checked all my settings and they were OK. On the on the last step above, I hit restore factory defaults. I'm not sure what that did, but I now hear my GPS!
