Got my new Ryker - didn't even make it a mile
lokiryker
So last Friday I stopped by the dealer to pick-up my brand new 2021 Ryker 900 with only 1 mile on the odometer. I pulled out and didn't even make it a half mile because I stopped at an intersection and the engine cut out and I was like: did I do something wrong? I restarted it again and it shut off. The high temperature warning flashed on the display and I could see smoke coming out of the front end. I managed to get it started and turned around and brought it back to the dealer who quickly rushed it into the shop. They thought it was the temperature sensor so they replaced it and the coolant, but turns out it may be the water pump because it's not pumping. Apparently this is the second brand new bike they've had come in from the factory with the same issue and I'm not sure how it even made it past inspection.
So now I have to wait to next week for them to fix the issue and hopefully not run into anything else on the way. I'm lucky I wasn't on the highway because I was a mile away.
Yikes!
My grandfather bought a new Ford post-WW2 and it overheated consistently. The dealer discovered that there was no impeller in the water pump. :shocked:
Yikes!
That would piss a guy off!!!
.....So now I have to wait to next week for them to fix the issue and hopefully not run into anything else on the way. I'm lucky I wasn't on the highway because I was a mile away.
And so would that!!!!!
The good thing. The dealer is working with you and did not say it would be two months or more before they would be able to look at it. :bowdown:
Yeah, still not happy about it, but is what it is. Told them after they "fix" the problem to test drive it for like 5-10 miles to make sure there's no issues.
They said they did, but with only 1 mile on the odometer I don't think they honestly did unless they just did a circle around the block.
Wife bought a 2020 Ryker in June 2020. Worked great but in November the fan started running constantly. Took it to the dealer in Feb after things warned up. Took 6 weeks to get approval from Can-Am but apparently the thermostat self destructed and clogged the whole cooling system. After a month in the shop
they replaced the thermostat, the radiator and the water pump impeller. All under warranty. Put another 1000 miles on it since and no issues so far. Got 5500 miles on it since last June and no other issues.
Every new Motorcycle delivered from our Dealership starting in the early 70's to this day shows between 7 and 10 miles on the odometer. I would not take delivery of any new Spyder or Ryker with out a signed off thural test ride.........Or its No Deal
By the way, this protects the dealership as well from the new customer trying to pull something over on the Dealer or Manufacturer...........
Shop called me back. They said they damaged the water pump gear during assembly and need to order a new one. So probably not going to see it for another week.
Got my bike dropped off today and the water pump issue was fixed. I drove it for an hour.
Now as a newbie I can't find any guides on how you're supposed to setup your seating posture. I had a foot cramp about an hour in.
At least they were honest with you - that may not speak ideally to their competence, but it does speak well of their character.
Everyone is different I suppose but I have mine set up so my foot pegs are all the way forward and my handlebars all the way back. I also load up my outside foot when turning too so my legs/feet stay active and not just resting on the pegs.
By "loading up" I mean that when taking a left turn I push down on the outside peg with my right foot and vice versa for the other side.
I had my pegs way too close to my body I pushed them as far up as possible. That solved the foot cramps. :)
Put about 20 miles on it last 24 hours just getting used to it. Def a blast.
Little old skool trick on the bars - get comfy in the saddle, close your eyes, and reach out to where your hands think the grips should be. Adjust the bars accordingly. Sounds screwy, but it works.
Ah yes, the casual slacker position. :ohyea:
You have what I'm missing. The driver backrest. Unfortunately, no one makes one for the driver if they have the comfort seat for driver and passenger. I'm going to making my own...just need to find the right back rest pad to modify.
I'm getting the comfort seat as well, but it's on back order. Same with the aluminum handguards. I ordered a couple sling mods as well.
