Good Vibrations (sarcasm)
ArmyJoe
I've already had vibration issues with the rear, almost losing my license plate light and my license plate. Now I have a problem in the front. I noticed this morning I'm missing the bolt to the right of the trunk hinge and the one on the left was about to fall out.
Are there any other places I should keep an eye on?
In addition to mentioning these to your dealer, I suggest a personal tour of your Spyder with appropriate tools, checking everything for tightness.
I would say you have other issues. After 31,000 miles I have never tightened anything or had anything fall off.
What were the vibration issues you had with the rear? I feel something that doesn't seem right when riding and I keep telling my dealer about it, but they keep coming back with "can't reproduce the problem". Ive noticed the rear sprocket is quite hot after a ride, so I'm thinking the belt alignment and/or tension is wrong?
The nuts / bolts holding the license plate light and the license plate came loose. This is my first bike, so don't know enough to know when something doesn't feel right.
For the first few weeks, I was riding at low RPMs compared to most. Now I try to shift somewhere around 3500-4000. I'll keep an eye on the parts and see if that makes a difference.
Good Vibrations....
With less than 2,000 on the bike, the 3 bolts on the ride side of the tail section fell out, then the exhaust bracket lost all bolts causing the exhaust to drop down (luckily this occurred while riding in town and my husband spotted it right away), then the license plate reflector/light cover fell off and most recently a bolt is now missing from the right front panel. The dealer has told me that vibration is a 'known issue' and it's up to the owner to be responsible and check all bolts frequently. :spyder: I told the dealer I hoped the front wheels didn't just fall off! :yikes: So, keep your tools handy, you must have one like mine!
