Gold Plug MP-01 - which washer did you use?
Billbathgate
Quick question for those who used this plug for their F3S ……did you use the washer that came with or the OEM washer ….all answers will be appreciated
The clutch cover drain plug washer, PN 420250640, Copper Washer, is the same for the all SE6 transmissions since the introduction of the 1330 ACE engine in 2014. While the service manual says to replace the Copper Washer each time an oil change is done, many Spyder owners reuse it. I don't; I use new copper washer every time. Gold Plug recommends the 12mm aluminum washer, SW-03, be changed each time the drain plug is removed. Do as you see fit.
