Getting fault codes C0040 and P2545 on start up - fixes?
remus
This morning I got the fault codes c0040 and p2545 as soon as U started the bike. I also got the check engine light and the yellow light on the lower left on the panel. does anyone know what these codes are and how to fix them? thank you in advance for your help I own a 2011 rss with the 998 motor.
According to MY SPYDER2 App; C0040: brake pedal switch failure. Check bulb, fuses, the switch itself
p2545: VSS failure , possibly related to brake fail, check harness as well. (Especially if find blown fuses)Default multiple codes on spyders : check battery -load test & clean tight connections.
Can-Am Codes
:chat:....Google has been somewhat helpful with codes.
I checked and 'c0040' was listed as 'right front wheel speed sensor (ABS). Give them a try and find things out. Lots of information on the Web.
Stay Healthy. ....:thumbup:
Fault Code c0040
:coffee:...Just checked this out on the Spyder Forum.
Fault Code C0040 ....has to do with the brake light switch.
Give the Spyder Forum a try. Questions just ask.
It turned out to be a dead cell in the battery. Battery was only 2 months old. Thanks again for the help
