Gerbing wiring on your 2014 yet?
ruthie
GOS member (Girls On Spyders)
wondering if anyone has wired they 2014 up for the Gerbing heated clothes yet? if so please pass on were you routed the wiring.
Thanks for any help on this.
I am about to start the process this weekend. I am curious about coming from the battery in the frunk to the passenger area. I picked up some a couple of these:
http://www.firstgear-usa.com/jack_panel_mount.html
Gonna install one in the middle of the buttons in the dash and one back by the heated hand grip controls for the passenger. Once I find out how to come from the battery to there, that is.
I watched the tech do mine; he took off left side panel and ran it back so that it came out under the center notion? box, which I want I wanted. I then taped it so that the end sticks just out of the seat. In summer it goes under the seat. I've found that the controler clips nicely on the front left edge of the seat and plugs in there to the hot wire.
Wiring heated jacket on trike.
Wire direct from battery to left speaker grill. You can snake wires straight down to battery box. Use the female jack attached to the grill. Looks great. See earlier post for first gear weather proof jack.
I used a similar set up and have it locate in the right side panel just left of the glove box, in front of the seat. It is fed from my custom fuse panel, hot key on.
