Loaded on phone....will not recognize the Sygic programm.
I have looked everywhere for a Genius maps user manual....help! After going to settings, while connected the spyder , I cannot get out of setting to go back to the main screen.
Hi all, i have connected to Genius maps through BRP Connect and have found that it is operating through Bluetooth, same as music, is this normal?
Is there any advantage to plugging in to the USB apart from charging my ph, i do find the volume isn't great and make sure the volume is turned up on the ph,
i have the latest software update 20.8
After some thought. Maybe try this. Take your phone out to your Spyder. Turn on the ignition key and wait for the two to BT connect. Do not plug in the usb cable. When they have BT connected. If it has not happened automatically. Start a music player from your phone. Then try increasing the volume on your phone. If a message comes up warning about damaging your hearing. Choose ignore or something like that. Then it will allow you to increase the phone volume to full. You will not have to do this again except maybe after a phone OS update.
Good advice.
Another mention is that, depending on your situation, it's possible your phone is already BT connected with something in the house - so it won't auto-connect. You'd need to manually tell it to connect to BRP. Happened to me this afternoon.
You can have many BT connections to the phone. On the odd occasion it might have a glitch but 99% of the time it will connect. I have my Apple watch connected all the time and turning the bike on and no problems connecting.
