gas gauge
You've got an RTS (I think!), so it's currently got the fuel gauge out in one of the pods...
I think that you've got to disconnect the external pods :shocked: in order for it to show the fuel level on the main screen...
Yup, Bob is correct
IMG_20120229_180109.jpg2011-11-07 16.07.31.jpg2011-09-15 15.29.13.jpgEasiest & cheapest (free) mod you can do. Remove the 4 bolts holding the dash cluter in place & unplug BOTH the gas gauge & temp. gauge, YOU HAVE TO UNPLUG BOTH, or you could cause issues. You can wrap the "live"plug ends or just push them back into the dash. Of course, do all this with the Power of the Spyder OFF. Once done, replace the dash cluster & Power Up your Spyder & BOTH the gas & temp. should show on your Left & Right sides of your LCD screen. They will toggle with your Audio Volume on one side & the rear suspension when you push the "Softer or Firmer" setting for the rear air suspension. Job done, ENJOY!
Or, like many here, myself included, you can take advantage of having the two pods available now for other mods. We used the power sourse from the one side to power our Garmin GPS & the other side to Power & house our Teddy-Cam, while the other side houses a Ram-Mounted drink holder for our long distance & daily travels. Hope this helps & WELCOME TO THE SPYDER-HOOD :yes:
View attachment 42462View attachment 42463View attachment 42464Easiest & cheapest (free) mod you can do. Remove the 4 bolts holding the dash cluter in place & unplug BOTH the gas gauge & temp. gauge, YOU HAVE TO UNPLUG BOTH, or you could cause issues. You can wrap the "live"plug ends or just push them back into the dash. Of course, do all this with the Power of the Spyder OFF. Once done, replace the dash cluster & Power Up your Spyder & BOTH the gas & temp. should show on your Left & Right sides of your LCD screen. They will toggle with your Audio Volume on one side & the rear suspension when you push the "Softer or Firmer" setting for the rear air suspension. Job done, ENJOY!
Thanks how did you mout your garmin?
