I bought a Dodge 6 1/2" black bolt on fuel door on Amazon. Marked the edges of the gas cap on the body panels. Lowered the seat and held the gas door up to were I wanted it an marked the inside and outside frame edges were the bolt holes would be and marked them too. Cut out the seat cover and foam. took my multi tool and cut the seat pan. You need to take all the mounting hardware and decorative nuts and bolts off. When I cut the cover, I only cut to the seam of the stitched in panel to prevent possible tearing. I tool a sheetrock knife and twisted the point thru the seat cover where the six screws would go then drilled thru the pan, being careful to not wrap the cover around the drill.(tip, clean the bit after each hole because the plastic will melt onto the drill and grab the seat cover>BE CAREFUL!!!!) I used black, high temp rv silicon to seal the inside padding then covered that with strips of gorilla tape and on the underside of pan, cover tape with more silicon to help hold it. I made sure to tuck the tape outer edge under the door ring. This cleaned it up.(Tip 2. I would not cut out the seat cover. I would now cut it from the center out in straight lines to the inner edge of the ring on the door and then silicone the padding and then fold the cover strips in over that and attach them to the pan. Still would maybe want to tape those too. I used stainless steel nuts and bolts. I double nutted them and lock and flat washers. You will need 2'' + or - long bolts. cut them off an add some kind of cover over the top nut to protect the body panel. I used some heat shield cloth and silicon to do this. The other ones cleared find but do some dry run slow closing with the door open to check.
:yes:I'm tech slow and cannot remember how to get pics on here. I have some and hope to post.
