Garmin 660 question about audio
Yes. If connected correctly. Easy place to start. Check the pins on the mount and the pads on the Garmin. Inspect for any damage or dirt on the contact surfaces.
Hi Guys
I think you will have to pass an audio cable, from the GPS to the audio output on the left side, and go plug it into the top case.
I ave i have a 2014 d, after me its a good way to do.
FlyBoy2121
Hi Guys
FlyBoy2121
Why would you do that? The audio from the gps connects to the dedicated gps input for the radio located around the rear right of the fuel tank. The GPS power source is there too. That allows the ability to listen to any audio source with the gps interrupting with it's prompts.
I Billybovine
I did not know, and I have a Freecom 2 intercome, I hear directly in my helmet, when you drive at 65 miles an hour the radio you hear almost nothing. Thank you for reseigning.
FlyBoy2121
