FYI - HCM Oil Filter Change
lstayner
When changing oil this week, I also changed the HCM filter. You need to change the engine oil at the same time as there is a considerable amount of oil in the HCM housing. The filter is buried under all the tupperware. You have to remove the large side cover to get to the bottom bolts. I initially took the small panel off down by the brake thinking that I could remove the filter through that access. Not a chance. For you DIYer's out there, it isn't a terrible job. Just make sure you organize the fasteners that you remove so you can get them back in the correct place.
:chat:...Thanks for the Heads-up. Change engine oil, oil filter, and HCM filter at the same time. You are right about the amazing things about Spyders.
So you need to have your Dealer Technician do this or DIY.
28K miles is the Can-Am requirement.
Stay Healthy. ....:thumbup:
:chat:...Thanks for the Heads-up. Change engine oil, oil filter and HCM filter at the same time. You are right about the amazing things about Spyders.
DIY...It just isn't that hard. A long torx drive/ extension with a wobble end makes it a little easier on some of the bolts. Rags ,strategically placed, keep any mess to a minimum. A few minutes of idle to purge air and shifting with no load is all it takes.
It's outlined on YouTube and here.
Lew L
After changing the HCM filter, do you need to do any special procedure in BUDS? I'm doing the 28k maintenance schedule.
Thanks :f_spider: :f_spider:
Ps: I just did what I should have done first... checked the Forum - BUDS not needed. :ohyea:
On my F3-S the filter and its cover practically stick out in the breeze.
At 28K my HCM filter was as clean as a new one so, I just put it back on. No reason to waste $$. JMHO
Interesting that BUDS is not needed, I was at a Dealer open house recently where they pull the Tupperware off on the right side of the RT, but the Tech doing the Demo said when you do the HCM Filter, you need to connect to BUDS... BTW, the other thing they said was if you need the serial number for the engine, they can get that for you in BUDS
* It IS a fact that you don't need BUDS for replacing the HCM filter. I know, as many others have known, having changed the filter ourselves.
* The dealer's tech, demo-ing the RT, might say that as the dealer will charge an extra fee for plugging in the BUDS system.
There is much discussion here about whether or not you need BUDS after changing your HCM filter. The service manual says you MUST use BUDS to accomplish the HCM Venting procedure. Many people here have changed their filter without BUDS. You decide.
