Fuses?
I'm having trouble with my parking brake not setting. Added fluid, no help. I'm curious if there's a fuse panel I could check just to see if it might be that simple, but I'll be darned if I know where a fuse box is? Manuel's no help... anybody know? TIA
Because you posted your question in the RT forum I will guess you have a RT. Is that correct?
Since the fuses have changed for different model years. What model year is it?
The fuse information is in the owner's manual. Can't tell you the page number because I don't the year.
Sorry about that. Yes, it's an RT-S, 2012. I looked again, where do you see fuse's in the manuel? Seems odd, I typically check fuses first. Are they under that panel with the computer logo inscripted on it accessable in the frunk? Thanks
Worked 4 me
MY WIFES RT had the issue several months ago. I couldn't diagnose what was causing it. Pushed all fuses tight in their sockets, no help. Finally pryed the brake switch from bike to check for current, it was hot. Pulled off all leads to switch cleaned contacts and reassembled. Worked and the issue went away.
Page 146 shows the location of both fuse boxes with pictures. Page 147 has description of fuses.
The descriptions are cryptic maybe one of the RT folks can tell you which fuse to look at.
